Onex107 wrote:Onex107 wrote:Just keep in mind fellow aeronauts. The Onex fuel system is designed to only operate correctly in positive G's. Negative G's could cause you to run out of gas and vent liquid from the tank vent.
And I might add, the Onex tank vents out the bottom of the plane whereas the Sonex vents on the windshield and gasoline on the windshield results in cracks. That's why mine needs replacement.
matthait wrote:The videos are impressive.
Did you need to modify the fuel system to support the manuvers?
Im not sure its practical but I was wondering how, if at all, the onex / sonex could stay inverted in flight. Im assuming at most ots during a manuver that causes a positive g on the airframe. But if trying to fly inverted on purpose at steady state conditions how long would be reasonable? A few seconds, not at all?
Is there a modification i should make now before i install the fuel tank that would facilitate this or is the engine and its oil sump the limiting factor?
