Battery location on tri-gear.
Postby lgoodenow » Sun Feb 16, 2014 2:29 pm
Have required battery. Where does it fit on the firewall? Plans are not helpful for tri-gear.
lgoodenow
Re: Battery location on tri-gear.
Postby Mike53 » Sun Feb 16, 2014 3:45 pm
Mike
Antoine de Saint-Exupery
Mike53
Postby Onex107 » Wed Apr 02, 2014 5:33 pm
The battery will not go where the plans show it if you have the Odesy, spelling, battery recommended. I put mine up to where the firewall angle breaks and as far right, looking aft, as I could. The only problem is the top of the nose gear tube is right under the battery box and if the spring allows it to jump up it will hit the battery box. I shortened the nose gear tube as much as possible and I have enough clearance below the box I think. Time and hard landings will tell.
OneX 107
N2107X
Onex107
Return to Onex
Users browsing this forum: No registered users and 27 guests
