Jacking up a Onex
Re: Jacking up a Onex
Postby WesRagle » Mon Nov 22, 2021 9:21 pm
Hi Guys,
I finally broke down and got the Harbor Freight lift table to jack up the Onex for maintenance in the hangar.
Ref.: https://www.harborfreight.com/1000-lb-capacity-hydraulic-table-cart-60438.html.
Worked perfect in conjunction with a proper height saw horse.
With the saw horse slid far enough forward that the airplane is a tad nose down all of the lifting load is on the landing gear with the table never touching the bottom of the plane.
Thanks for the suggestion Scott.
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Hummel 2400 w/Zenith Carb
Prince P Tip 54x50
First Flight 06/23/2020
42.8 Hrs. as of 10/30/21
WesRagle
Postby Tnhelm » Thu Nov 25, 2021 9:44 pm
How well does it work with one wing folded up and the other extended? Any chance it tends to tip toward the extended wing?
Thelm
OneX 137
Tnhelm
Return to Onex
