ONX-F20-02
Re: ONX-F20-02
Postby GOIX » Sun Feb 17, 2013 9:41 am
Regarding the matched hole parts , I've found the machined and flat parts to be bang on . I have been finding issues with some channel parts. These parts are laser cut flat with the rivet holes done at that time . If the part is not bent perfectly on the brake it can cause the parts to be too narrow or wide with the holes in the wrong location . I've also had some flanges bent a little askew with the hole line wandering .
My technique with channel parts is to now confirm and tweak the flange angles first . I then measure the centre line of the rivet holes and see if the part was bent correctly . I also measure the width of the channel and see if it has a constant width .
Having done all that , I'm now ready to try to massage all the parts into the best configuration to match all the holes in the assembly to minimize hole elongation .
If you just trust the holes and cleco and rivet you may not be getting the best outcome .
Marc
Marc
Onex 0024
C-GOIX reserved
GOIX
Return to Onex
Users browsing this forum: No registered users and 23 guests
