by dhogue » Sun Nov 27, 2016 5:21 pm
Recently completed the Onex turtledeck installation.
I riveted the two sides to the splice channel together, flat, on top of a table without pre-bending/shaping.
After installing the turtle deck assembly, per the plans, I have no waves between the skins and splice channel rivets.
Tip:
When riveting the turtle deck assembly to the turtledeck formers I did have to make small bends in the former tabs in order to close gaps between the former tabs and the inside of the turtledeck skin also when riveting the turtledeck to the formers I had someone pushing the tabs up into the inside skins before pulling the rivet. This worked out well as there are no dimples in the skin at the formers and was not the difficult process I originally thought it would be.
Don Hogue
Onex 0173: Tailwheel: AeroVee Turbo.
Horiz/Vert Stabs, Rudder/Elevators, Fwd/IB/OB/Aileron Bellcranks on Ribs and Main Fwd/Aft Center Wing Spars, Fuselage : Complete.
WIP: Wings
