ONX-L01-10: What Drill bit to use for AN5-12A bolts?
PostPosted: Sat Jun 01, 2019 2:54 pm
by dhogue
Hello,
I'm now working on installing the Landing Gear leg (ONX-L01-10) shown on plans page ONX-L01(Rev E) View's AA and BB.
The bolt called out is AN5-12A. I measured the bolt Diameter to be .310 in. I tried using a 5/16 in diameter drill (.310 in diameter) but the resulting hole is too large - that is - the bolt is loose/has noticeable play in the hole.
What I am writing to ask those who have completed this part of the build is: What size drill results in a snug fit for the AN5-12A bolt?
As always, thank you for your time, experience and helpful advise.
Don
Re: ONX-L01-10: What Drill bit to use for AN5-12A bolts?
PostPosted: Sat Jun 01, 2019 3:26 pm
Don,
I can't speak to that size directly, but for critical bolts I generally drill undersize and my last pass is a reamer. For a 1/2" AN bolt I am reaming to something like .4975" IIRC. I mic'ed up a bunch of bolts to guess at the reamer size.
PostPosted: Mon Jun 03, 2019 9:31 am
by dhogue
Thanks Bryan.
Reamers ordered.
PostPosted: Tue Jun 04, 2019 10:14 am
by Zack
This is what I came up with. I labeled the reamers and drill bits (in their baggies) AN3, AN4, etc. I always step up unless I have access to a milling machine with a rigid setup (very rarely).
AN3
Nominal 3/16"
(0.186 - 0.189)
Drill Bit: #13 (0.185)
Reamer: #12 (0.189)
AN4
Nominal 1/4"
(.246 - .249)
Drill Bit: D (0.246)
Reamer: E (0.250)
Reamer: F (0.257)
AN5
Nominal 5/16"
(.309 - .312)
Drill Bit: 5/16 (0.3125)
Reamer: O (0.316)
Reamer: P (0.323)
AN6
Nominal 3/8"
(.371 - .374)
Drill Bit: 3/8 (0.375)
Reamer: V (0.377)
Reamer: W (0.3860)
PostPosted: Thu Jun 06, 2019 2:20 pm
by dhogue
Thanks Zack. Very helpful.
