ONX-L01-10: What Drill bit to use for AN5-12A bolts?
Discussion for Onex builders on specific plans page experience. These posts are limited to technical suggestions such as assembly order, challenges, or techniques related to specific plans pages.
Postby dhogue » Sat Jun 01, 2019 2:54 pm
Hello,
I'm now working on installing the Landing Gear leg (ONX-L01-10) shown on plans page ONX-L01(Rev E) View's AA and BB.
The bolt called out is AN5-12A. I measured the bolt Diameter to be .310 in. I tried using a 5/16 in diameter drill (.310 in diameter) but the resulting hole is too large - that is - the bolt is loose/has noticeable play in the hole.
What I am writing to ask those who have completed this part of the build is: What size drill results in a snug fit for the AN5-12A bolt?
As always, thank you for your time, experience and helpful advise.
Don
Don Hogue
WIP: Wings
dhogue
Re: ONX-L01-10: What Drill bit to use for AN5-12A bolts?
Postby Bryan Cotton » Sat Jun 01, 2019 3:26 pm
Don,
I can't speak to that size directly, but for critical bolts I generally drill undersize and my last pass is a reamer. For a 1/2" AN bolt I am reaming to something like .4975" IIRC. I mic'ed up a bunch of bolts to guess at the reamer size.
Postby dhogue » Mon Jun 03, 2019 9:31 am
Thanks Bryan.
Reamers ordered.
Don Hogue
WIP: Wings
dhogue
Postby Zack » Tue Jun 04, 2019 10:14 am
This is what I came up with. I labeled the reamers and drill bits (in their baggies) AN3, AN4, etc. I always step up unless I have access to a milling machine with a rigid setup (very rarely).
AN3
Nominal 3/16"
(0.186 - 0.189)
Drill Bit: #13 (0.185)
Reamer: #12 (0.189)
AN4
Nominal 1/4"
(.246 - .249)
Drill Bit: D (0.246)
Reamer: E (0.250)
Reamer: F (0.257)
AN5
Nominal 5/16"
(.309 - .312)
Drill Bit: 5/16 (0.3125)
Reamer: O (0.316)
Reamer: P (0.323)
AN6
Nominal 3/8"
(.371 - .374)
Drill Bit: 3/8 (0.375)
Reamer: V (0.377)
Reamer: W (0.3860)
Zack
Postby dhogue » Thu Jun 06, 2019 2:20 pm
Thanks Zack. Very helpful.
Don Hogue
WIP: Wings
dhogue
Return to Onex Plans
