How: Insert Tailwheel spring into Pivot fitting?
Discussion for Onex builders on specific plans page experience. These posts are limited to technical suggestions such as assembly order, challenges, or techniques related to specific plans pages.
Postby dhogue » Sat Mar 17, 2018 6:22 pm
Hello Sonex/Onex builders,
I am writing to ask how did you install SNX-LO3-03 Tail Wheel Spring into the ONX-LO3-04 Tailwheel Pivot fitting?
The plans page is ONX-LO3
The spring will not slide into the pivot fitting. I tried to tap it in with a hard rubber mallot but it does not go in at all.
Don
Don Hogue
WIP: Wings
dhogue
Re: How: Insert Tailwheel spring into Pivot fitting?
Postby Direct C51 » Sat Mar 17, 2018 6:25 pm
Don, that sounds like the better problem to have than it fitting quite loosely like mine did. I would just use some sand paper or a scotch brite pad on a stick chucked in a drill motor to remove some of the powder coating in the pivot assembly. Remove just enough to get it in. The tighter the better.
Direct C51
Postby dhogue » Mon Mar 19, 2018 3:33 pm
Thank you Sir!
That worked.
Don
Don Hogue
WIP: Wings
dhogue
Return to Onex Plans
