F08-08 Flap Detent Angle
Postby vernd » Tue May 13, 2014 11:59 pm
Hi all -
I know that some of you have modified the "flap detent angle" to add an additional notch of flap and some have also modified the shape of the notch.
Just about to start making this part - so looking for any guidance around some of these modifications. Are they worthwhile - or best to just build per plans. What have your experiences been with the modifications and would you make them again.
Any guidance or thots appreciated.
Thanks much.....
Vern
Sonex 613 (slow scratch build)
Alberta, Canada
Vern Dueck - Innisfail, Alberta
Sonex 613 Slow Scratchbuild
Taildragger , Aerovee(turbo),
vernd
Re: F08-08 Flap Detent Angle
Postby DCASonex » Wed May 14, 2014 8:47 am
Third notch half way between original two notches no big deal to add. However, would modify all notches to provide more relief at aft end of the pockets. Bend on top of flap lever causes lever to twist when pulled. That twist tends to bind the lever in the notches, pulling harder tries to twist it more and locks even harder. Been there, done that, could not retract flaps when checking stall characteristics on first flight. Eventually converted to electric flap operator. Switch right next to throttle, no need top move hand from throttle, and with hydraulic brakes, can keep shoulder belts tight from takeoff through landing.
Postby Rynoth » Wed May 14, 2014 10:16 am
Great advice on the notches, Thanks. I'll be making this part soon as well.
Postby vernd » Wed May 14, 2014 1:53 pm
Thanks for the info David. On the relief at the back of each notch - any guidance on how much clearance to add?
Thanks again....Vern
Sonex 613
vernd
Postby planeolbob » Wed May 14, 2014 6:23 pm
planeolbob
Postby DCASonex » Thu May 15, 2014 8:38 am
I cut each notch deeper into the angle at at aft end of notch resulting in back of notch at about a at about a 7 to 8 degree angle.
Postby vernd » Fri May 16, 2014 12:27 am
Thanks for the input - much appreciated.
Vern
vernd
Return to Sonex Plans
