SNB F19: drilling holes for bolts
Postby SP1 » Tue Aug 18, 2020 8:21 pm
Hello
Does anyone have any suggestions on how to drill the bolt holes? Especially the forward most? I’m trying to figure out a way to get a drill in that space, but it’s pretty tight in either direction. Do you basically have to bend SNB F26-07 out of the way? Thanks very much. Picture attached
SP1
Re: SNB F19: drilling holes for bolts
Postby Spaceman » Wed Aug 19, 2020 12:33 am
I think I got some of the holes drilled like you have there, then removed the big former and drilled it from above with a long sorta flexible bit. Maybe I did flex the little piece out of the way slightly like you said!
Chris Paegelow
http://paegelow.blogspot.com/
Spaceman
Postby SP1 » Wed Aug 19, 2020 11:01 pm
Thanks Chris. I forgot about those long bits. I also have those flexible drill shafts from Amazon that could do the job as well.
SP1
Return to Sonex Plans
