Fitting vertical fin
Postby Sonex1243 » Sat Jul 11, 2020 10:54 pm
I have been struggling with fitting the vertical fin in place. It is extremely tight and have been flexing the vertical fin rear spar and tail post assembly a bit to let it slide into place. The problem is then trying to get the forward spar to clear the turtledeck skin in order to slide it in place. I have already slightly bent the turtledeck skin and slightly tweaked the tail post on the side that is riveted while trying to mesh the entire vertical in place to see how much trimming is needed on the skin.
What have others done and have you run into this? Is it as simple as trimming the turtledeck skins enough to clearance the forward spar?
Riveted side that flexes the tail post while trying to slide the vertical in place
Forward spar scraping and slightly bending the skin edge while trying to position in the slot
Non riveted / rudder hinge side that flexes outward while trying to slide the vertical in place
Ken S
SONEX #1243 N424SX (reserved)
Tail complete, wings done
Fuselage on gear
Jab 3300 received!
Sonex1243
Re: Fitting vertical fin
Postby gammaxy » Sun Jul 12, 2020 12:28 am
I think you'll be fine once you trim the turtledeck. It's a pretty common interference. I think the plans dimensions would work if you could teleport the tail into position, but otherwise you have to do some trimming.
This picture's not great, but you might notice I just blended the notch much wider until it fit. Can't tell there was ever a notch there.
Postby Rofomoto » Sun Jul 12, 2020 6:51 am
Had to widen the turtle deck cut out a 1/4” to each side. 1/2” total.
1735
Longassproject
Rofomoto
Postby Sonex1243 » Sun Jul 12, 2020 1:07 pm
gammaxy wrote:I think you'll be fine once you trim the turtledeck. It's a pretty common interference. I think the plans dimensions would work if you could teleport the tail into position, but otherwise you have to do some trimming.
That's the visual cue I needed! Looks like you trimmed the entire turtledeck edge even with the front spar face. Was there enough meat for the fairing to attach to the turtledeck after trimming?
Ken S
Fuselage on gear
Jab 3300 received!
Sonex1243
Postby sonex1374 » Mon Jul 13, 2020 8:19 am
It looks like the very aft end of the fuselage upper longerons might be pinching the vertical stab spar as well. If that happens, you might need to file this down a bit. The very edge could conceivably dig into the vertical stab spar material and cause scratches or stress risers. The plans show this edge getting a slight shaping to it, but at the time it's not clear why. I've noticed this occurrence in several projects and they tend to need a bit more clearance at the time the tail goes into place.
Jeff
Jeff Shultz
Sonex TD, 3300, AeroInjector
Kansas City, MO
http://www.sonex604.com
sonex1374
Postby pfhoeycfi » Mon Jul 13, 2020 8:22 am
I trimmed the turtledeck as well...
Peter Hoey
Philadelphia Glider Council
Also built Sonerai IIL N86PH
pfhoeycfi
Postby Sonex1243 » Tue Jul 14, 2020 3:56 pm
sonex1374 wrote:It looks like the very aft end of the fuselage upper longerons might be pinching the vertical stab spar as well. If that happens, you might need to file this down a bit. The very edge could conceivably dig into the vertical stab spar material and cause scratches or stress risers. The plans show this edge getting a slight shaping to it, but at the time it's not clear why. I've noticed this occurrence in several projects and they tend to need a bit more clearance at the time the tail goes into place. Jeff
Thanks for pointing that out Jeff. I might be ok depending on getting the vertical in the right spot for drilling the forward attach bolts. If I need to file, it might be easier to just drill out the rivets and remove the tail post.
For now, I am struggling with the forward spar and have to use a small "C" clamp just to draw it in to the forward horizontal spar.
Ken S
Fuselage on gear
Jab 3300 received!
Sonex1243
Return to Sonex Plans
