You mean the wing attach blocks? E is the inboard one and D is the tip. E shows the angle that the rib mounts to. Also note D is looking aft at left main spar, and E is looking forward at same.
Bryan Cotton Poplar Grove, IL C77 Waiex 191 N191YX Taildragger, Aerovee, acro ailerons dual sticks with sport trainer controls Prebuilt spars and machined angle kit Year 2 flying and approaching 200 hours December 23
I’m looking at the build up of the spacers at the front of the rear rib where it attaches to the spar. sNX-W14. Spacers -02 and -03. On E-E only lists one spacer but looks the same as D-D.
1735 Longassproject E-A-G-L-E-S Eagles (next year 16- 0)
Rick524 wrote:It looks like aft ribs 4 thru 11 get the .032 spacer and rib 12 doesn't. I guess its hard to show a .032 spacer, or lack of, in the pictures.
Rick C-GRIX
Thanx so the E-E rib doesn’t have the 1/8 thick spacer?
