peter anson wrote:Not Correct. The elevator isn't mass balanced so even if you are using the cable operated trim tab, you need some sort of spring balance for the elevator. SNX-C01 mentions a bungee to support the elevator level or slightly down and warns you not to cut it too short. I used a small pulley on one end and a bungee from the other end going around the pulley and going back to an adjustable cleat, a small yacht fitting, so that the bungee is easily adjustable.
