GordonTurner wrote:I think it was mentioned in an earlier post that the hydraulic brakes instructions give the hole layout for TRICYCLE gear....a minor oversight by the company.
kevinh wrote: However, now that I have everything up on gear with the fuse mostly done I can see that the wheel pant is no where near level wrt. the longeron. It is quite a bit too nose down. Is it possible that the prepunched hole in that metal plate is not in the correct location? I'm considering removing the pin rotating the brake/pant assembly and then drilling a new hole for that pin...
