SNX-F21 detail E
PostPosted: Sun Jan 01, 2017 3:08 pm
by lstinthot
Im working on the upper cross tie bolts that are inside the box. The bolts coming down into the box from inside the plane are what im looking to put the final bolts in. Why do the plans call for AN 7A bolt and 2 washers on each hole? Wouldn't a AN-6A bolt with one washer work good? Are people putting a washer on top and one on bottom? The sites I looked at could not make out these bolts real good.
Thanks
Mike
Re: SNX-F21 detail E
PostPosted: Sun Jan 01, 2017 5:12 pm
Mike,
In my opinion many Sonex callouts are one size long. I have often gone down a size because I am nuts about that sort of thing. But, two washers won't kill anything.
PostPosted: Sun Jan 01, 2017 5:52 pm
by kevinh
yep - I used -6 bolts, with two washers on the aft bolt, and one on the forward bolt (because that's what a test fit showed would work). The aft bolt has one less layer of 0.025" to fit through because of how the box is built.
PostPosted: Sun Jan 01, 2017 10:53 pm
by lstinthot
That is what I was thinking. I have been putting double washer on many parts.
PostPosted: Mon Jan 02, 2017 2:51 am
by sonex892.
lstinthot wrote:That is what I was thinking. I have been putting double washer on many parts.
I believe up to 3 washers under the nut is acceptable practice. That said, before starting I had every size needed per the plans. I had to order more hardware to comply with the 3 or less washer rule.
Steve
Sonex 892
