jowens wrote:Did you enlarge the hole in the forward root rib? Remove the material between the two lightening holes.
Also, not sure if you have riveted on the main ribs. If you have not, consider updrilling the wing bolt holes to 3/8" with a drill press and the spars carefully clamped together. numerous posts on wing rigging available :)
I wish i would have test fit my wing skins before I drilled the root ribs. The skins are "a point of truth" and a good confirmation of the root rib location measurements. My root rib location was ok, just would have been less stress.
Bryan Cotton wrote:Mike,
Wait until your skins are all clecoed on. Fit the root rib by hand so it looks good, then clamp to the angles. Once clamped go wild with the drill. This is really pretty easy. Also, open the hole in the forward root rib now, before you do any mounting. Gives better access.
