Former and seat belt interference
Postby lstinthot » Fri Nov 25, 2016 3:52 pm
What is the general concensus to aliviate the interference between the seat belt attach bracket and the #3 former? I have seen one picture where someone looks like he took a hammer and made it fit. I was thinking about notching the former and reinforcing the former.
Scratch building #1604
Tail dragger
Thinking Turbo Aerovee
lstinthot
Re: Former and seat belt interference
Postby Bryan Cotton » Fri Nov 25, 2016 8:42 pm
I notched and reinforced.
Postby Area 51% » Sun Nov 27, 2016 1:36 pm
Yet another aspect of the build that has probably plagued the matched-hole crowd more than the scratchers. I'm sure the factory stand on the subject is "you are the first to have a problem" if you were to ask.
I opted to remove enough material from the shoulder harness bracket to clear the former, then put a doubler on the bracket. For me, it was easier to work with the heavier gauge material.
Postby Darick » Sun Nov 27, 2016 2:02 pm
I notched the seat belt attach piece enough to clear the former. I just now looked at it and it looks like I only had to remove about 1/8 to 1/4 which I figured wasn't enough to worry about. If I hit something with enough force to make that piece fail I'll have bigger problems to deal with.
Darick Gundy
Sonex #1646
N417DG
First flight! 10/21/2017
Darick
Return to Sonex Plans
