snxT03-02 main horiz spar fitting
Postby sonex1332 » Mon Dec 07, 2015 7:44 pm
Plans say to make from 2.5 in. Angle, trim to 2-29/64, meaning a 3/64 cut. But the end view shows the champhered edge. Is this a CAD interpertation, or do I trim the edge and round it? Thanks in advance - couldn't find anythig on this using the search.
Still slow/scratch building 6 years later.
sonex1332
Re: snxT03-02 main horiz spar fitting
Postby rizzz » Mon Dec 07, 2015 8:02 pm
Here are some pictures of those "spar angles from hell" when I made them, hard to see but I don't think I had a chamfered edge:
Postby sonex1332 » Mon Dec 07, 2015 8:21 pm
Thanks. Looks like you did trim off the 3/32 though. Thats about the width of the kerf on my table saw, so I was worried about blade chatter. Maybe I'll try a router. I'm beginning to suspect this will be a practice piece. Yours turn turned out well!
sonex1332
Postby lstinthot » Mon Dec 07, 2015 11:22 pm
I did not send the part thru the table saw I used the vixen file. The part will have a small chamfer left after removing the 3/64".
Www.mysonex.net
March 13, 2013 has some more pictures
Scratch building tail dragged
Scratch building #1604
Tail dragger
Thinking Turbo Aerovee
lstinthot
Postby peter anson » Tue Dec 08, 2015 8:14 am
The drawing just shows that when you remove that 3/64" you haven't removed all of the original edge radius. A file will remove 3/64 very easily.
Peter Anson
Sonex 894
Postby sonex1332 » Tue Dec 08, 2015 11:03 am
Thanks everyone. I'll grab my file and get at it.
sonex1332
Return to Sonex Plans
