Gripdana wrote:On the plans there is a note that an access hole is not needed on the cowl to fill the oil. Can the oil be topped off if needed without removing the cowl? I see that I can reach the dip stick with no problem through the front air inlet.
wlarson861 wrote:If your cowl is un-painted or you are still building, fitting an oil fill door is pretty simple. I did mine with a round aluminum cover about the size of the other inspection panels and used nut plates to hold it. At home I usually have the cowling off enough times for other reasons that I don't need the opening, but I have used it often enough to be glad I installed it. Other builders have spent the time to install hinges and recessed latches which look great and are easier to use than mine at a cost of more time. After flying for 3 years I'm glad I spent a couple of hours installing an oil filler access opening, taking the cowl off to add 4 ounces of oil and then re-installing the cowl would take all the time I had for flying on most days.
