Landing gear on SNX-L01
Postby Brett » Sat Oct 18, 2014 8:34 pm
I have just seen the engineering note at the top of the page SNX - L01 regarding the upper bolt in the landing gear attach bracket. The new bolt required is a standard AN4-30 using a castle nut and cotter pin. Of course I have just realised the bolts supplied from Aircraft Spruce are the older type AN4C30A SS undrilled bolts and two nyloc nuts. I expect the solution is to just order again the correct hardware however is there any other reason these bolts can't be used? I assume the plans were changed for a reason.
Sonex 1645
VH-VWS
Tailwheel
Former Aerovee Turbo
Rotax 912
Brett
Re: Landing gear on SNX-L01
Postby Fastcapy » Sat Oct 18, 2014 8:53 pm
Mike Beck
Oshkosh, WI (KOSH)
Sonex #1145 N920MB
Fastcapy
Postby Brett » Sat Oct 18, 2014 10:14 pm
Cheers Mike, will get the correct bolts :)
-Brett
Sonex 1645
VH-VWS
Tailwheel
Rotax 912
Brett
Postby Rynoth » Sat Oct 18, 2014 11:26 pm
Mike is correct. Here is a link to the service bulletin.
http://www.sonexaircraft.com/support/se ... etins.html
Postby daleandee » Sat Oct 18, 2014 11:49 pm
Brett wrote:Cheers Mike, will get the correct bolts :)
Someone else mentioned that the concern is only with elevated heat levels. I believe that 450ºF was what was quoted and if your gear legs are ever that hot you have other things to be worried about. ;)
But as I understood it if one was concerned about it that a sacrificial coating could be used on the bolts. I used a light coat of wheel bearing grease when installing the bolts.
Also keep in mind that the axle bolts are part of the Service Bulletin. I needed a different size axle bolt as I have the Tracy O'Brien axles on my Sonex supplied gear legs.
Just a heads up ...
Dale
N319WF
Postby planeolbob » Sun Oct 19, 2014 7:31 pm
Here are some photos of my gear bolts breaking at the middle of this album
https://www.flickr.com/photos/53052604@ ... 343703412/
Bob
planeolbob
Return to Sonex Plans
