Main Spar assembly support 'blocks'
Postby n502pd » Wed Jul 16, 2014 4:25 pm
I hope this is the correct place to ask this.. Somewhere I remember seeing someone who had made assembly support blocks for the main wing spars, and had shown a picture of them in use. I have searched here and find nothing. Does anyone have a better memory than I, as to where those pictures can be found? thanks in advance! :D
Joe Nelsen
scratch built :D
Flying @81.7
KGYI/N. Tx Reg/Perrin Field
n502pd
Re: Main Spar assembly support 'blocks'
Postby gammaxy » Wed Jul 16, 2014 8:44 pm
I made mine on my garage floor with the Sonex bucking bar. I used a few 2x4 blocks to raise the spar so it was roughly parallel to the bucking bar surface, but low enough that the weight of the spar on the bucking bar was holding the rivet firmly in place.
Are these the blocks you are referring to or did you see a more sophisticated technique?
Postby mike.smith » Wed Jul 16, 2014 10:41 pm
n502pd wrote:I hope this is the correct place to ask this.. Somewhere I remember seeing someone who had made assembly support blocks for the main wing spars, and had shown a picture of them in use. I have searched here and find nothing. Does anyone have a better memory than I, as to where those pictures can be found? thanks in advance! :D
Was it maybe my web site?
http://www.mykitlog.com/users/display_l ... 42&row=256
Sonex #439
Postby n502pd » Wed Jul 16, 2014 11:03 pm
It sure was!! thanks much! I dont see you using the spar cap spacers? maybe you already set the dimention? Any way I get the idea. Thanks again!
Joe :D :D
Joe Nelsen
scratch built :D
Flying @81.7
n502pd
Postby n502pd » Thu Jul 17, 2014 4:49 pm
Thanks Chris for the reply. Mike had what I was wanting. I am not quite to the actual point of final assembly yet, and will keep what you have shown as reference! :)
Joe Nelsen
scratch built :D
Flying @81.7
n502pd
Postby Gripdana » Fri Jul 18, 2014 11:32 am
I made and used Mike's support blocks. It was an easy method to use. I used a pneumatic rivet gun which is well worth the expense.
Dana Baker
Scratch Built
First Flight March 8, 2015
Gripdana
Return to Sonex Plans
