SNX-W08
SNX-W08
Postby Darick » Sat Jun 14, 2014 9:40 am
Detail "A". Bolt direction holding W20-02 and W20-03 is not clear. Here is tech support guidance in quotes...
"The two lower bolts are installed from the forward side.
The bottom note applies to the top and bottom bolt, the top note applies to
the four bolts in the center of the spar."
However, don't let the top view confuse you. I think the bolt is in backwards on the drawing and should be installed from the AFT side, not the forward side as in the drawing. I sent a note to tech support on this.
Darick Gundy
Sonex #1646
N417DG
First flight! 10/21/2017
Darick
Return to Sonex Plans
