Canopy install
Re: Canopy install
Postby wlarson861 » Fri Jul 21, 2017 12:52 am
I did my cowl first but either order should be ok.
Bill Larson
N861SX
wlarson861
Re: Canopy install
Postby NWade » Fri Jul 21, 2017 2:28 am
I did my canopy first and think its fine to do so. Just get the forward bow as high as you can and be very careful not to trim too much from the lexan forward windscreen, and you'll be fine.
Good luck,
--Noel
Sonex #1339
Re: Canopy install
Postby Corby202 » Fri Jul 21, 2017 8:51 pm
Is it okay to do canopy before cowl?
I wouldn't recommend that. In my opinion, to get the front of the plane looking nice I think its important to get a straight line from the cowling above the prop hub to the top of the canopy bow.
Phil Bird
Sonex 759 JAB 2.2 Tailwheel
Mittagong NSW Australia
Corby202
Re: Canopy install
Postby Darick » Fri Jul 21, 2017 9:41 pm
I took a piece of the canopy trimmings and applied heat from a hair dryer, in search of a way to relieve the canopy stress at the hinge and latch hook attachments. I held the 1" x 20" piece in an roughly six inch radius and applied heat with an old Conair hair dryer on high. After about 5 minutes the plexiglass was not resisting as much to the bend and took a slight set to the six inch radius.
It wasn't very scientific but proved the point that it could be changed to a new radius. Now how much did that change the specs? Will it be more brittle, more prone to cracking, less flexible? Any engineers out there who could tell us?
I then tried a higher watt heat gun and was easily able to bend the test strip to a one inch radius.
My thought is to hold the canopy tight against the frame sides with, say a 1" dowel rod and apply heat to the area directly behind the dowel rod, in an attempt to put a slight bend or at least enough heat to make that area "relax".
I know it sounds kind of risky with an expensive canopy. Perhaps someone with an old cracked canopy might be able to investigate how difficult this would be. Another reason this is called experimental.
All thoughts welcome.
Darick Gundy
Sonex #1646
N417DG
First flight! 10/21/2017
Darick
Re: Canopy install
Postby jeff0196 » Fri Jul 21, 2017 10:35 pm
Jeffrey W
Waiex 0196
AeroVee Turbo
jeff0196
Re: Canopy install
Postby WaiexN143NM » Sat Jul 22, 2017 8:01 am
Hi darick,
How did the heat do to the optics, still clear?
Re: Canopy install
Postby lpaaruule » Sat Jul 22, 2017 10:25 am
I tried a heat gun to get my first canopy to fit better. The back of the canopy was extending beyond the turtledeck about 1/4". I tried heating is and bending it in. Unfortunately I discovered that it shrinks slightly from the heat.
The heat also removed the nice, natural, looking curvature of the canopy, and messed up the optics...I got it way too hot.
Maybe a hair dryer would be ok, but my first canopy became a hot mess. The more I tried to fix it, the worse it got.
I didn't just blindly hit one spot with the heat gun. I was careful to only heat the area for a few seconds at a time.
Paul LaRue
Sonex N454EE Plans# 1509
Jabiru 3300
First Flight 12/21/2017
lpaaruule
Re: Canopy install
Postby Darick » Sat Jul 22, 2017 10:50 am
Thanks Jeff, I watched the video.
Michael, on the small piece I tested the optics did not change. If you are in Tucson, I may be visiting the area in the fall.
Darick Gundy
Sonex #1646
N417DG
Darick
Re: Canopy install
Postby jeff0196 » Sun Jul 23, 2017 12:02 am
Good, the EAA really does have some nice videos.
To add to Paul's comment on the plexiglas shrinking with the heat gun, he may have experienced the heat gun removing the moisture from the plexiglas. It is well documented that plexiglas changes dimensions with changes in moisture. The changes are usually said to take a days when exposed to the natural humidity changes, but I think the heat gun can speed up the process. The change in dimension from humidity is one of the reasons the mounting holes are to be drilled oversize.
http://www.plexiglas.com/export/sites/p ... rbtion.pdf
Jeffrey W
Waiex 0196
AeroVee Turbo
jeff0196
Return to Sonex Plans
