Tail spring slop
Re: Tail spring slop
Postby Sonex1243 » Fri Dec 14, 2018 10:59 am
I would like to do the same with mine while it is upside down for engine mount fitting. Do you all happen to have a source for the SS shim and epoxy?
Thanks.
Ken S
SONEX #1243 N424SX (reserved)
Tail complete, wings done
Fuselage on gear
Jab 3300 received!
Sonex1243
Postby Bryan Cotton » Fri Dec 14, 2018 11:26 am
I used this:
https://m.aircraftspruce.com/catalog/wp ... key=340448
Did not bother with a stainless shim. When you bond it in upside down it will be fixed so the shock loads are metal to metal anyway.
Postby Sonex1243 » Sat Dec 15, 2018 2:23 pm
Bryan Cotton wrote:I used this: https://m.aircraftspruce.com/catalog/wp ... key=340448
Thanks Bryan, I want to epoxy my main gear axles as well, just a slight wiggle on them. I would probably have to wait until spring / summer though since the 50 degree and above weather is gone for now! Was the temps in your hanger the reason for the ceramic heater setup?
Ken S
Fuselage on gear
Jab 3300 received!
Sonex1243
Postby Bryan Cotton » Sat Dec 15, 2018 5:37 pm
Ken,
I keep my hangar heat at 40, and turn it up to 60 when I am there. The ceramic heater kept that joint nice and toasty while it cured.
Postby mike.smith » Sat Dec 15, 2018 7:01 pm
Just a thought... if you epoxy your gear, what happens if you need to replace it someday from damage or wear?
Postby Bryan Cotton » Sat Dec 15, 2018 7:45 pm
Heat it up, pull it out.
Return to Sonex Plans
