Lower attach angle on Stabilator
Postby gregsonex » Tue Mar 05, 2024 4:10 pm
Hey Folks,
Any suggestions on best way to bolt on the lower attach angle (WIX-T09-04) as part of stabilator installation (WIX-T07) after you've already riveted on the fuselage skins? It's really hard to get the right angle to get a washer and nut on the inside of the bolt--i tried both the hole on the tailcone as well as reaching from the access panel in the lower skin. It obviously would've been much easier to bolt on if I did it before riveting on the lower fuselage skin :(
gregsonex
Re: Lower attach angle on Stabilator
Postby WilliamBatten » Wed Mar 06, 2024 10:35 am
Fast build kit builders have the same issue - the skins are already riveted when you receive the kit.
I did not see a way to place the nut on the back side of this angle for the lower bolts. So, I inserted the bolts from the back side for the lower angle - and then installed the angle. I then had access to install the nuts from the front. The top row of bolts was still a bit tricky - but doable. Hopefully my picture will clarify.
Bill
Bill
N67WX - Reserved
Waiex-B Taildragger
Jabiru 3300
WilliamBatten
Postby Area 51% » Wed Mar 06, 2024 12:59 pm
Are you talking about the bolts shown in the above pictures, or the two vertical bolts that hold the assembly to the longerons?
The Sonex has 4" round access holes in the aft fuselage for some reason. You might ask Tech support if it's OK to install one of them to gain access. Otherwise, the other option is to get Adam Cotton to come over with a handful of sharp drill bits. Not sure of his current rates, but he used to work for food.
I guess you missed the note on the bottom of page F-18 that would have you not rivet the bottom skin in place till the end of the show.
Postby BobDz » Wed Mar 06, 2024 2:07 pm
This thread immediately reminded me of an old Flinstones cartoon. Fred was out of work and going through the classifieds looking for a job. First job, person with long skinny fingers to put cotton into pill bottles. Second job, person with long skinny fingers to take cotton out of pill bottles.
Bob Dz...
Sonex B, Tri-gear
N624DZ (reserved)
BobDz
Postby Bryan Cotton » Wed Mar 06, 2024 3:29 pm
Area 51% wrote:Otherwise, the other option is to get Adam Cotton to come over with a handful of sharp drill bits. Not sure of his current rates, but he used to work for food.
Now that he is gainfully employed at Woodward I think you will find his rates have gone up a prohibitive amount.
Postby BobDz » Thu Mar 07, 2024 9:37 am
[quote="Bryan Cotton"
Now that he is gainfully employed at Woodward I think you will find his rates have gone up a prohibitive amount.[/quote]
Kind of sad when our built in labor force ages out.
Bob Dz...
Sonex B, Tri-gear
N624DZ (reserved)
BobDz
Postby gregsonex » Sat Mar 09, 2024 12:34 pm
Thanks Bill. I was referring to the vertical bolts that attach the assembly to the longeron as Area51% mentioned. I’ll try using a magnet, a longer socket wrench or some other tool to get the nuts attached.
gregsonex
Return to Waiex Plans
Users browsing this forum: Bing [Bot] and 4 guests
