by n307tw » Thu Apr 08, 2021 11:06 am
Hi Wingnut! (cool name)
If your flap motor has the potentiometer you will see thin red black and white wires coming out of the smaller device attached to the motor. The thicker twisted pair of red and black is for the motor itself. I successfully wired my potentiometer into the Garmin system as follows: red: 12v+DC, black: ground, and white: signal. The potentiometer sends out an analog value on that white wire not digital. The Garmin allows you to program each flap position as a value coming over the signal wire. As an example, set your flaps to 0 degrees and it may come up with a value of 200ohms. Save that data point and set the flaps to 10 degrees and save that corresponding ohms value. 20 degrees, 30 degrees, etc,.
I am not acutely familiar with Dynon systems and as such I do not know how this is possible in the Dynon system. I am sure they have a similar way of integrating the signal and custom data points but that would be something you would have to research. For instance, their engine management device may have the ability to include position sensors such as the flap potentiometer and I would wire it up based on what the Dynon manual states. I hope this helps, feel free to reach out if you have any other questions.
-Tim
Tim Wrede
Long Island, NY
Sonex-B #18, Nosedragger
Aeromomentum AM15, Garmin G3X
My Build Site
