WIX-W12 Rear Spar Assembly
Posted: Thu Nov 03, 2016 8:01 am
Regarding the rib attach pilot holes - vertical locations:
There is a note: "For proper Rib alignment the rib attach holes must be located accurately. Use Laser Cut Formed Rib to establish locations, reference WIX-W11 drawing."
So I went ahead and marked the spar channel based on the measurements given on W12 for the vertical locations. Then if I take any of the aft ribs and just lay it up against the spar channel I can get the marks to line up with the rib holes exactly. Should I align the rib flange with the top of the spar channel and mark / pilot hold drill the holes now - or wait until I am assembling the wing substructure and align and pilot hole drill directly through the rib flanges? Seems to me there is more chance for error trying to drill pilot holes in the spar channel directly through the rib flange pilot holes.
Thanks.
Thanks.
