Hello Everyone! I didn't want to post anything until I had made some substantial progress. Today I achieved the milestone of getting the new motor mount, motor, battery, and controller test fit to the front of my Xenos!
Always great to see electric projects, since I'd like to try it some day myself. Sounds like you have plenty of experience already. I'll definitely be following your progress.
Thanks for sharing. I'm really looking forward to watching your progress!
I've been close to buying a Zero (for riding) in the past but when their motor system is an adequate replacement for the Rotax 503 in my Kolb, I just may need to find a "donor".
Kip
2010 Waiex 0082 (first flight May 2010) Jabiru 3300 #1637 and #3035 Dynon D-180 Becker radios Garmin GDL 82 ADS-B 1175 hours 48 states visited Based near Atlanta
Also flying a... 2000 Kolb Firestar II, Rotax 503, 575 hours
Very cool! Where I work they are building a lab for developing electric hybrid aircraft, but on a larger scale. Keep us posted and good luck!
Bryan Cotton Poplar Grove, IL C77 Waiex 191 N191YX Taildragger, Aerovee, acro ailerons dual sticks with sport trainer controls Prebuilt spars and machined angle kit Year 2 flying and approaching 200 hours December 23
Curiously enough, I was about to post here asking if someone had already gone the electric power route in a XENOS or in any other Sonex... :-) So now I know the answer to question!
When I started building my XENOS I already had made my mind to put an electric motor in it. Therefore, XENOS 59 please keep us posted about your electric powering venture, better yet with pictures of your installation.
Looking good. My other toy is a Quad City Challenger II with a 503 Rotax and a belt drive reduction. It uses a 50mm GT3 cog belt which is more than adequate for 54 hp. Your belt looks a little smallish for 80hp equivalent. jmho
Bill Volcko XNS0068 Xenos A N68WV 99% flush rivets Aerovee and Prince P-Tip MGL Discovery Lite w/ Sandia STX 165R V6 First hole 4/1/16 First flight 8/24/18 Phase I complete...finally!!! Also flying a Challenger II since 1999
There are two buttons in the edit bar, youtu_be and youtube. Pick the one that looks like your link.
The belt looks small, I agree. But the peak and average torque of an electric motor are about the same. On a two stroke all the torque is jammed onto 30, maybe 40 degrees of crankshaft rotation for a given cylinder. For a parallel twin let's estimate the peak torque as 360/70 ~ 5x peak to nominal torque.
I don't know how the two reduction ratios compare, so that also affects torque.
We learned this peak torque lesson the hard way at Sikorsky years ago. A first generation UAV we built and flew had a 50 HP Wankel rotary. Generation 2 had two 25 HP, 2-cylinder opposed two strokes. Parts that were twice as strong as required for the Wankel were half as strong as required for one of the opposed twins. The Wankel is as close as you get to electric in a recip.
