scotttro wrote:I'm working on an older Waiex. Yes, I had that problem. Did what you said - cut off the tip, subtracted the extra, stuck it back on. Here's a pic of it post-trim.
Mike53 wrote:Had the same issue with the Onex. Simply cut a strip from the open end which will automatically shorten it.Assuming it's like the Onex's
Cheers.
Carlos Trigo wrote:scotttro wrote:I'm working on an older Waiex. Yes, I had that problem. Did what you said - cut off the tip, subtracted the extra, stuck it back on. Here's a pic of it post-trim.
Scott
The photo you posted seems to be before trim, still with the line where you cut it.
Is this correct?
In that case can you please post the post-trim picture?
Carlos
Carlos Trigo wrote:Is there no problem for the aerodynamic design by that stabilator length reduction?
Carlos
Carlos Trigo wrote:Carlos Trigo wrote:scotttro wrote:I'm working on an older Waiex. Yes, I had that problem. Did what you said - cut off the tip, subtracted the extra, stuck it back on. Here's a pic of it post-trim.
Scott
Is this correct?
Carlos
Scott
Now that I looked better to the picture you posted, I think I saw that you didn’t cut the trailing edge.
You did cut the tip where the blue is, eliminated the extra length, and then just glued the cut piece again.
Am I correct now?
Carlos
