wieght and Balance number
Postby bvolcko38 » Thu Jul 05, 2018 3:04 pm
I doing the final weight and balance calculations, I have found that my dimensions from spinner to wing leading edge, (book 56.5", mine 55.5") and spinner to bottom of firewall (book 47.5" mine 46") differ quite a bit. What to do? I understand that the MAC is the key, but I wonder why the book numbers differ from mine so much. I built exactly to the plans.
BV
Bill Volcko XNS0068
Aerovee and Prince P-Tip
V6
First hole 4/1/16
First flight 8/24/18
Phase I complete...finally!!!
bvolcko38
Re: wieght and Balance number
Postby peter anson » Thu Jul 05, 2018 9:29 pm
Hi Bill, for a start, don't worry about it. A large part of the difference between your numbers and the book values could be a different propeller. I used to have a prop fitted that had a much thinner hub than the usual Sensenich. OK, I can't think of a reason for the other missing 1/2". Just pick your reference point, tip of the spinner or whatever, and stick to it. Even the distance from your reference to the leading edge is going to vary at least 1/8" from one wing to the other because of the spar overlap.
Postby wlarson861 » Fri Jul 06, 2018 1:46 am
your spinner being too low could indicate the need for shims under the bottom mounts. Check to see that the center line of the engine is correct to the airframe.
Bill Larson
N861SX
wlarson861
Postby bvolcko38 » Fri Jul 06, 2018 6:35 am
I think its the Prince prop. I'm told its hub is thinner than the Sensinich
Bill Volcko XNS0068
V6
First hole 4/1/16
bvolcko38
Return to Xenos
Users browsing this forum: Bing [Bot] and 8 guests
