The 1st wing I made I marked the chordline on the rib and measured up 2-3/4" on my square while trying to clamp the rib in position. Since I'm not an octopus, this was not very accurate. Checking with a straightedge on top of the ribs, they all needed slight adjustment. I started the 2nd wing yesterday & thought of marking the 2-3/4" mark jig. This was much faster. I could line up the bullseye in the rib tooling hole, clamp in postion, then fine tune with a straight edge on top of the ribs.
Rick
Xenos 0057
- Rib cl.jpg (83.71 KiB) Viewed 2989 times
- Rib mark.jpg (65.83 KiB) Viewed 2989 times
