sonex1374 wrote:Paul Johnson wrote:... you can fit 380-150-5, this is basically a 6″ wide tyre with somewhat more height but fits on the 5″ wheel...
To help put this in perspective, a standard 500-5 tire is typically 14.2" in diameter, 5.00 inches wide and fits on a 5" wheel hub. The 380-150-5 is 15" in diameter (380mm), 5.9 inches wide (150mm) and fits on a 5" hub. I believe this is about the biggest tire you can easily use on a standard Azusa hub.
Jeff
Carlos Trigo wrote:Do you also know the dimensions of the stock tires?
