Corby202 wrote:Having not posted pictures before, not sure if this will work but here goes.
My plane is just about ready to be signed off and the first flight shortly after. I have already tried a few taxi tests on the sealed runway and grass taxiway. Impressions so far:-
I was pleasantly surprised by the turn radius, I had read that the standard tailwheel set up was terrible, obviously its nothing like a swiveling tail wheel but it should be fine.
The drumming noise from the back of the plane is high but the ANR headset soon fixed that.
The amount of pressure required on the pedals to steer is much higher then I am used to so I will have to be mindful of that.
Visibility when taxying, worse then some better then most.
Not sure about the brake handle, being so used to toe brakes my hand never leaves the throttle. Undecided on that one.
https://photos.google.com/u/0/album/AF1 ... M-cCs0r4jJ
Corby202 wrote:Thanks Michael. I have tried setting it up as a shared photo collection, this link might work.
https://goo.gl/photos/5MzBabA2aaphKqP96
