Darick's Sonex #1646
Re: Darick's Sonex #1646
Postby kevinh » Sat Jul 30, 2016 10:35 pm
Hi Darick,
Thank you for your great wing mating write-up! It will be great extra help when I get to this point! -Kevin
kevinh
Postby Darick » Sun Aug 21, 2016 7:33 pm
The panel is as complete as possible without the engine in place. So I started working on the engine this week.
For those AeroVee owners...the outside of the case looks like a moon landscape...lots of ugly casting marks. Paint will hardly cover all that up. Has anyone tried to finish the outside for a nicer look or am I just too overly picky and wasting time? If you did make it look nice, how did you do it?...Dremel tool with wire wheel...sandblast?
Darick Gundy
Sonex #1646
N417DG
First flight! 10/21/2017
Darick
Postby Darick » Sun Aug 21, 2016 7:58 pm
I got the preassembled hub option. If your connecting rods come with the "star" type bolt heads, you will need a 12 point 11mm socket.
Also there is a way to check the connecting rod bearing clearance with "plastigage", as mentioned in the assembly manual that refers to Tom Wilson's VW engine repair book. Mine were all fine but I wondered what you would do if the clearance was out of tolerance.(?)
Darick Gundy
Sonex #1646
N417DG
Darick
Postby wlarson861 » Mon Aug 22, 2016 12:24 am
Just remember all those ugly pits and peaks in the surface increase the surface area of the case. More surface area = more cooling. It's an airplane engine not a 32 Ford hot rod!
Bill Larson
N861SX
wlarson861
Postby Darick » Mon Aug 22, 2016 11:02 am
Excellent point! That's enough to change my mind. Thanks!
Darick Gundy
Sonex #1646
N417DG
Darick
Postby Darick » Sun Sep 18, 2016 9:09 pm
AeroVee assembly push rod ends....
After cutting to the correct length, the small ball ends must be pushed in. Mine had a LOT of interference and would not go in even when the tube was heated with a heat gun. I solved this finally by sanding down the part of the ball end that gets inserted into the push tube, as the first step.
150 grit, slowest drill press speed, for 2 minutes
The second step was to increase the push rod ID by running a 5/16 drill into the end and then sanding a little at a time until the ball end would go in about half way.
Test fit before heating, Ball will slip in half way...
Finally, the tube was heated with a heat gun, ball inserted, then tapped in....
Remember to clean out the tube before tapping in the ball end, much like you would clean out a gun barrel, throughly!
Darick Gundy
Sonex #1646
N417DG
Darick
Postby Darick » Tue Oct 11, 2016 6:16 pm
Engine is on the plane!
Next step is wiring the ignition and MGL E1 engine monitor.
Flying goal is first quarter of 2017.
Darick Gundy
Sonex #1646
N417DG
Darick
Postby Darick » Fri Oct 28, 2016 11:25 am
Trying to keep up with Bryan's high standards, I've decided to carve my prop too. It will need a small weight on the short end.
Ok I admit it. I'm not carving my prop. This "torque reaction arm" was how I kept the crank from rotating while I torqued the gland nut.
Darick Gundy
Sonex #1646
N417DG
Darick
Postby Darick » Sun Nov 06, 2016 9:25 pm
The only wires remaining to be hooked up are CHT and EGT.
Darick Gundy
Sonex #1646
N417DG
Darick
Postby Darick » Mon Nov 21, 2016 8:20 pm
Rather than add a separate deflector to the bottom mount oil baffle I just cut out the opening on just three sides then bent up. It took a lot of trial fitting and cutting but I like the way it turned out.
Darick Gundy
Sonex #1646
N417DG
Darick
Return to Photo Album
Users browsing this forum: Google Adsense [Bot] and 24 guests
