by WesRagle » Fri Oct 02, 2020 1:34 pm
Hey Billy,
Come on, give us some more information. How'd the engine perform?? I've been waiting to hear about the stroker :-)
As long as the engine is working well you are not likely to hurt yourself. Just make sure it idles fine and provides power for a balk when needed.
Please keep us posted on your progress. There isn't enough chatter on the list about the actual mechanics of flying these airplanes. Those with a lot of hours don't see what all the fuss is about and those still building don't have much say.
I looked back at your photos and the pic I saw of the flap detent angle didn't seem to have the three flap positions most Sonex guys have. It also had a tit on the last setting. Just know that that tit will require that you torque the handle with your wrist to dump flaps on a go-around. Back in my Sonex days I never used full flaps. 2/3 was plenty.
I know what the first flight is like. You feel, smell, hear, and see everything. It's kinda like extreme sports without the exercise :-) All the adrenaline can cause over control.
I'll leave you with a few thoughts from a guy who's working his way back.
1) If the engine is fine the airplane won't quit flying. So, next time up just slow the airplane down and practice deploying and retracting the flaps. You may find that it's not as hard as it first seems. At first you will wiggle the plane when you pull but that will go away with practice.
2) Landing a tail wheel plane is simple in concept. Just line up with the runway, keep the longitudinal perfectly aligned with the center line, control your speed, don't flare too high, and hold the airplane off until you're in the three point attitude. Once you're on the ground pin the tail for tail wheel steering and keep it straight with your feet. Apply breaks as needed. With no wind, that's pretty much it. It just requires practice.
3) After a few flights you might want to fly down the runway in landing configuration, at maybe 75 or 80 mph, and practice sliding the airplane back and forth from the "right lane" to the "left lane" of the runway, cross controlling to maintain perfect longitudinal alignment. It's kinda fun.
4) Sonex airplanes are noisy. They shake, rattle and roll and the canopy whistles. That can be a little disconcerting at first. After a while you realize the airplane is just talking to you. When you finally grease that first landing you will still know for sure you're on the ground because that tail wheel is hooked up to a megaphone pointed directly at the cockpit screaming "I'm down". After a while you can hear if you're getting off speed on final by the sound of the wind noise.
5) Get an experienced/current tailwheel pilot to fly with you a few times. If they are an instructor their words will replay in your head every landing. Watch your speed. Don't dive at the runway. Hold it off, hold it off.... OK, pin the tail. Straight with your feet. Stay with it, stay with it!
6) Go to YouTube and watch videos. Jeff has published a bunch of videos and one specifically on pattern work. On one of them Jeff had a less than perfect landing. I think he called it a thumper :-) Mike has published a bunch too and has some less than perfect landings. Watch'em all. Come to think of it even my instructor had a less than perfect landing. Of course instead of balking or bouncing down the runway he instantly transitioned to a wheel landing. We'll maybe some day.
Don't get discouraged, all the fun you thought about, the pay dirt, is closer than you think.
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Hummel 2400 w/Zenith Carb
Prince P Tip 54x50
First Flight 06/23/2020
42.8 Hrs. as of 10/30/21
