by Darick » Mon Apr 18, 2016 10:44 pm
Bryan, I borrowed some of your photographic magic tricks. The wheels pants may look right, but they are just sitting on the wheels. Which brings up another question.
I've looked at many Sonex pictures to determine the best angle for the pants and it seems they look best if aligned with the longerons. However, the wheel pant mounting plate is pointed way down, about 10-15 degrees. I may just try to attach the pants level with the longerons and trim the mounting plate to minimize that 10-15 degrees. I'll let you know how that goes.
On another note, I didn't use the suggested way to get the toe in. Instead I aligned the axles using a laser and plumb bobs. After they were aligned, I used trigonometry to set the toe in at a distance of 36" out from the axle. Tangent of .7 degrees times 36" gives the correct answer. I know this description is a bit simplistic and it may be difficult to understand exactly how I did it. Maybe some day I'll try to explain it in detail if anyone is interested.
Darick Gundy
Sonex #1646
N417DG
First flight! 10/21/2017
