sonex892. wrote:Hi Billy. With a new welded tank, if it failed the test and had a leak, I would repair by welding.
If a welder wasn't available, I see no reason pro seal couldn't be applied externally at the leak site. Thats what you would do with a prosealed tank if it failed the test. Iv'e never heard of issues with proseal other than it stinks and is messy and horrible to use. However here are many stories of sloshing compound sealant failing, normally due to alcohol in the fuel.
Rofomoto wrote:sonex892. wrote:Hi Billy. With a new welded tank, if it failed the test and had a leak, I would repair by welding.
So what you’re saying is if my welded tank doesn’t leak now I shouldn’t use pro seal? Maybe just around exterior seams only.. is this correct. Thanx agayfor all the help. Billy
racaldwell wrote:I can verify that proseal can fix pinhole weld leaks. Over some years, I had some pinhole weld leaks on the joints of my One Design AL tank. First time I had Steen Aerolab reweld that location but then another leak returned. I prosealed the length of that edge and put an 3/4" x 0.025 AL angle over the proseal. That worked. A year later another seam started leaking so I then did all the straight seams. Never leaked again for the next 6 yrs I had it.
Rick Caldwell
Xenos 0057
