pappas wrote:I would do a pressure test. Not more than 5 lbs per square inch. Ad check with the factory to make sure that 5 lb psi spec is accurate. If it doesn't leak over a 24 hour period you are good to go.
sonex892. wrote:pappas wrote:I would do a pressure test. Not more than 5 lbs per square inch. Ad check with the factory to make sure that 5 lb psi spec is accurate. If it doesn't leak over a 24 hour period you are good to go.
5 psi might even be on the high side for a welded tank. The RV guys test their prosealed tanks by taping on a rubber glove to test for leaks, the inflated rubber glove is used to set the inflation pressure and it's also used as the leak indicator.
Sonex 892
Bryan Cotton wrote:RV tanks are riveted structures and pro-seal is required. Not for our tanks. I also used a balloon like Ryan.
