billy's plans built sonex 1735
Re: billy's plans built sonex 1735
Postby DCASonex » Thu Aug 08, 2019 9:16 am
Billy,
Are you sure you can get that thing out of there when completed ??
Postby Rofomoto » Thu Aug 08, 2019 1:56 pm
DCASonex wrote:Billy,
With wings and landing gear off but still have to knock out cellar door frame to get my 40 1/4” hole
1735
Longassproject
Rofomoto
Postby Rofomoto » Fri Aug 09, 2019 6:49 pm
Wings leveled, rigged, and clamped. Made this stainless steel drill guide bushing.
1735
Longassproject
Rofomoto
Postby Rofomoto » Sat Aug 10, 2019 5:36 pm
Good night sonex... wings rigged and drilled... not as bad as I was anticipating ..
1735
Longassproject
Rofomoto
Postby Rofomoto » Sun Aug 18, 2019 1:23 pm
Working on canopy frame. Put side channels on so no rivets on sides just bond into slot
1735
Longassproject
Rofomoto
Postby Rofomoto » Mon Aug 19, 2019 6:40 pm
Can someone explain to me what part pivots on control assembly where it mounts to front spar carry through tunnel? Is bolt stationary and bushing pivots on bolt? Is bolt and bushing stationary and assembly pivots on outside of bushing? Thanx for any help. Billy
1735
Longassproject
Rofomoto
Postby Rynoth » Mon Aug 19, 2019 8:29 pm
Rofomoto wrote:Can someone explain to me what part pivots on control assembly where it mounts to front spar carry through tunnel? Is bolt stationary and bushing pivots on bolt? Is bolt and bushing stationary and assembly pivots on outside of bushing? Thanx for any help. Billy
The bolt should pivot within the bushing. You want the movement/friction to be between the bushing and the steel bolt, not the bushing and (softer) aluminum. Sometimes you have to ream out the bushings a little bit if the bolt is too tight to pivot freely.
Postby Rofomoto » Mon Aug 19, 2019 8:38 pm
Rynoth wrote:
Rofomoto wrote:Can someone explain to me what part pivots on control assembly where it mounts to front spar carry through tunnel? Is bolt stationary and bushing pivots on bolt? Is bolt and bushing stationary and assembly pivots on outside of bushing? Thanx for any help. Billy.
The bolt should pivot within the bushing. You want the movement to be between the bushing and the steel bolt, not the bushing and (softer) aluminum. Sometimes you have to ream out the bushings a little bit if the bolt is too tight to pivot freely.
So the bushing should be a press fit in assembly?
1735
Longassproject
Rofomoto
Postby Rynoth » Mon Aug 19, 2019 8:51 pm
Ideally yea, into the aluminum part, although sometimes a too-tight press fit will shrink the inside of the bushing and cause the bolt to bind, so it's a delicate balance. I only recall one bushing that was spinning in the aluminum on me. I believe I applied some loctite to make the bushing grab the aluminum so the bolt would spin in the bushing instead
Postby Rofomoto » Mon Aug 19, 2019 9:26 pm
Thanx!
1735
Longassproject
Rofomoto
Return to Photo Album
