by Darick » Wed Feb 24, 2016 11:22 pm
Thanks Jake, I appreciate your overview and suggestions. Today I worked on the panel crossbar and I see what you mean. I will probably have to move the switches up a bit.
I'm going to add a 2" wide additional aluminum strip across the bottom like many other guys have done. But instead of putting switches there, my plan is to put a row of auto type blade fuses at that location. I've seen fuse boxes in groups of 4,6,10, etc.that would fit nicely, if mounted flush in this 2" strip. I'll be working on this idea as soon as I figure out how many fuses I'll need.
Darick Gundy
Sonex #1646
N417DG
First flight! 10/21/2017
