billy's plans built sonex 1735
Re: billy's plans built sonex 1735
Postby Rynoth » Fri Jun 21, 2019 11:58 am
Rofomoto wrote:What # drill bit for leading edge skin have you used pre- dimpling. Thanx billy
I used standard 1/8", which basically falls between a #30 and #31.
Postby Area 51% » Fri Jun 21, 2019 12:18 pm
It says specifically on page W07 not to use a #30. The holes can end up too big after the dimpling causing proud rivet mandrels and the possibility of the rivet pulling completely through. It calls for either a 31 or 32.
Seems to me I remember someone offering a dimple die set that has a 3/32 pilot for the 1/8 rivets. Then you can open up the holes to 1/8in after the process.
Postby WesRagle » Fri Jun 21, 2019 12:41 pm
Area 51% wrote:It says specifically on page W07 not to use a #30. The holes can end up too big after the dimpling causing proud rivet mandrels and the possibility of the rivet pulling completely through. It calls for either a 31 or 32.
Hi Randy,
I think this is what you are thinking of. Works just fine as far as I can see.
BTW, back in the day I drilled a sonex leading edge to #30 and then dimpled. Of course, while riveting the mandrels started pulling through. Another Tony S. tip was to use a hand puller and "pump" the rivet as it was being pulled. Apparently the pumping work hardens the mandrel and caused it to break before pulling through. It was a pain but very few mandrels pulled through using that method.
For the second wing I drilled to #32. I also chucked up my #30 dimple die in a drill press and "machined" it down to #32 with the edge of a file. Besides permanent damage to my #30 die, that worked just fine.
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Hummel 2400 w/Zenith Carb
Prince P Tip 54x50
First Flight 06/23/2020
42.8 Hrs. as of 10/30/21
WesRagle
Postby Rofomoto » Fri Jun 21, 2019 5:17 pm
Thanx guys.
1735
Longassproject
Rofomoto
Postby DCASonex » Sat Jun 22, 2019 8:21 am
This is from 7 years ago, but then the Sonex supplied dimple dies where made at a much steeper angle than necessary for the angle of the rivet heads, and that was major contributor to expanding the holes over-sized. Do not know what they are supplying today, but worth taking a look at. That die set had a 100 degree seat and an 80 degree nose. A 3/32" die set from Avery tool was a much shallower angle so made my own 1/8" die set, Used a 118 degree drill bit for the seat in the female half, with the nose part turned to 115 degrees. Did not open the holes anywhere near as much. Used a #32 drill bit for nice tight final fit, and selected suitable mandrel (nail) for the new die set to fit that # 32 hole..
Postby Rofomoto » Sat Jun 22, 2019 10:01 am
I have a 120 deg 1/8” die set from Cleveland tools. I did some practice dimples through #32 holes. It seems to work pushing through that size hole. Still thinking
1735
Longassproject
Rofomoto
Postby Rofomoto » Sun Jun 23, 2019 3:39 pm
Done dimples and deburring. Ready to close up. Not going to have lights but thinking of running wire. What size and number of wire should I run? Also how did you secure it? Thanx billy
1735
Longassproject
Rofomoto
Postby GordonTurner » Sun Jun 23, 2019 3:51 pm
Maybe larger than you will need.....I ran a twisted pair of 18GA to each wingtip for landing light (+ and -), plus a shielded 3-conductor 20GA for:
NAV
STROBE
STROBE SYNC
shield for ground.
Gordon
Postby Rofomoto » Sun Jun 23, 2019 4:14 pm
GordonTurner wrote:Maybe larger than you will need.....I ran a twisted pair of 18GA to each wingtip for landing light (+ and -), plus a shielded 3-conductor 20GA for:
NAV
STROBE
STROBE SYNC
shield for ground.
Gordon
Thanx Gordon. How and where did you route them
1735
Longassproject
Rofomoto
Postby GordonTurner » Sun Jun 23, 2019 10:31 pm
In conduit through the larger of the nose rib lightning holes, held with adel clamps on home made brackets.
Return to Photo Album
