billy's plans built sonex 1735
Re: billy's plans built sonex 1735
Postby Corby202 » Mon Jun 10, 2019 11:22 pm
I also added a strip of aluminium to the short side of the skin. Taped it in place so both edges met up evenly before pulling a vacuum. I used a length of 42mm steel water pipe to bend around but think 38mm would have been better.
Phil Bird
Sonex 759 JAB 2.2 Tailwheel
Mittagong NSW Australia
Corby202
Postby vernd » Tue Jun 11, 2019 9:46 am
Rofomoto wrote:
vernd wrote:Are you using steel pipe or plastic pipe? I'm close to bending my leading edges as well. Look forward to photos and updates.
Thanks.
1 1/2" pvc......is your skin cut and drilled? Billy
Haven't cut the skin out yet - still 4' x 12' sheet. My plan is to cut out but leave extra length on one side and cut to final length after bending. Was also planning to drill before bending.
Vern
Vern Dueck - Innisfail, Alberta
Sonex 613 Slow Scratchbuild
Taildragger , Aerovee(turbo),
vernd
Postby Rofomoto » Tue Jun 11, 2019 10:56 am
Area 51% wrote:Didn't work for me, no matter how hard I clamped the pipe down. Nature has it's way of evening things out.
Randy has finally convinced me my method is flawed. I will add length to the short side. Guess I’m pretty hardheaded. Thanx to everyone for helping me with this. Billy
1735
Longassproject
Rofomoto
Postby Rofomoto » Fri Jun 14, 2019 7:17 am
Ok made some of the last few pieces for the wings. The long piece with matching holes is for the 3/4” extension to the one side of the leading edge skin for bending. It should make the bending even. Also wing tip blanks and landing gear fairings.
1735
Longassproject
Rofomoto
Postby Rofomoto » Sat Jun 15, 2019 7:52 pm
When your first plane ride is a 1929 Waco this is how you feel
[url=http://s639.photobucket.com/user/billykerchner/media/44C962DC-4714-40EE-9519-70A38600D2C9_zps9xb4b6cf.jpeg.html]Image[/
1735
Longassproject
Rofomoto
Postby Rofomoto » Mon Jun 17, 2019 5:28 pm
First one worked. Thanx all
1735
Longassproject
Rofomoto
Postby Rofomoto » Tue Jun 18, 2019 12:05 pm
Looks like it’s gonna work.
1735
Longassproject
Rofomoto
Postby Rofomoto » Tue Jun 18, 2019 6:50 pm
Couple small little nose rib dents. I’ll try to fix when I take it apart to deburr.
1735
Longassproject
Rofomoto
Postby Rofomoto » Fri Jun 21, 2019 11:09 am
What # drill bit for leading edge skin have you used pre- dimpling. Thanx billy
1735
Longassproject
Rofomoto
Postby Bryan Cotton » Fri Jun 21, 2019 11:17 am
Either #30 or #31. I found #32 to be too tight.
Return to Photo Album
