billy's plans built sonex 1735
Re: billy's plans built sonex 1735
Postby Rofomoto » Fri May 03, 2019 8:06 pm
One flap done.
1735
Longassproject
Rofomoto
Postby Rofomoto » Sun May 05, 2019 10:53 am
Second flap done....now for the last big things..the dreaded wing assembly.. still have 8 more aft ribs to make then ready....a little over a years work so far.
1735
Longassproject
Rofomoto
Postby Rofomoto » Thu May 09, 2019 10:25 pm
Just gonna wing it
1735
Longassproject
Rofomoto
Postby Rofomoto » Fri May 10, 2019 6:47 pm
Rear spar, aft ribs and forward ribs pilot drilled
1735
Longassproject
Rofomoto
Postby Rofomoto » Thu May 16, 2019 10:07 am
Time for some skin
1735
Longassproject
Rofomoto
Postby Rofomoto » Mon May 20, 2019 8:49 pm
Before I rivet # 9 rib in one last check with you guys if it matters if control horn hits the lightning hole? Don’t know if control ever get this far...
1735
Longassproject
Rofomoto
Postby dbdevkc » Tue May 21, 2019 9:09 am
Mine are very close, but do not hit. But like you said, I'm not sure it matters.
Left
Right
[color=#800000]Kevin Conklin
Building Waiex #169
dbdevkc
Postby Rynoth » Tue May 21, 2019 10:22 am
Rofomoto wrote:Before I rivet # 9 rib in one last check with you guys if it matters if control horn hits the lightning hole? Don’t know if control ever get this far...
It's not a problem, the controls never get that far. If you look at 0:18 and 0:40 in this video of mine you'll see how close it gets to the lightening hole. There's nearly a full inch of clearance when the aileron hits the stops. You would probably run into issues of the shorter bellcrank>aileron pushrod binding up before the bellcrank reached the lightening hole anyway.
Video was taken after having pre-rigged the shorter pushrod, so the travel of the bellcrank should be about the same as what you end up with:
Postby Rofomoto » Tue May 21, 2019 10:27 am
[quote="dbdevkc"]Mine are very close, but do not hit. But like you said, I'm not sure it matters.
Left
Thanx kevin..really should know before assembly... maybe someone else may know if the movement actually travels through lightning hole at full deflection thanx billy
1735
Longassproject
Rofomoto
Postby Bryan Cotton » Tue May 21, 2019 12:18 pm
I think I bent the hole flange a bit just to be sure. With an inch of clearance it probably doesn't matter but it made me feel better at the time.
Return to Photo Album
