In the 3 point attitude the plate was 8 degrees nose down and the airplane was 9.5 degrees nose up. So, our hole pattern needed to rotate 17.5 degrees. We used this simple setup.
We used a piece of flashing to make a template. The blue lines show the nosewheel configuration, and the red lines are our new tailwheel configuration.
Sonex1243 wrote:After installing the wheels, the brake pucks scrubbed heavily on the brake disk with the pistons fully bottomed. I may work them down on the belt sander just enough so they don't interfere and let the wheel spin freely when setting the final axle nut location.
