billy's plans built sonex 1735
Re: billy's plans built sonex 1735
Postby Bryan Cotton » Thu Oct 25, 2018 1:09 pm
Rofomoto wrote:How much lower can the lower switch panel,that I’ve seen people do-on their instrument panel, go without leg interference? Looks to be about 1 1/2”. Thanx billy
Mine is 2.5". I am 5' 7.5" on a good day and Adam is closer to 5' 10".
Postby Rofomoto » Thu Oct 25, 2018 6:36 pm
I’m 5’ 10” so should be good to go. Thanx
1735
Longassproject
Rofomoto
Postby Rofomoto » Fri Oct 26, 2018 1:29 pm
Bryan. Do you have a picture of your full lower panel. Thanx billy
1735
Longassproject
Rofomoto
Postby Bryan Cotton » Fri Oct 26, 2018 2:13 pm
Billy,
Shoot me an email and I'll forward you my panel email from a couple years ago. My Gmail address is my first name, last name, and Waiex serial number (191) all jammed together.
Postby Rofomoto » Fri Oct 26, 2018 3:21 pm
Bryan Cotton wrote:Billy,
Email sent.
1735
Longassproject
Rofomoto
Postby Rofomoto » Sat Oct 27, 2018 1:06 pm
2” angle sub panel. My panel will be vertical so instrument panel will cover to the bottom of angle. It will also be bolted in and removable with complete panel.
1735
Longassproject
Rofomoto
Postby Rofomoto » Mon Oct 29, 2018 1:34 pm
Finish welding up axle mounts. Thinking about mounting axles first, install in mount, and then rotate in mount to get the .7 deg toe in.
Also my best helper stopped in to get to work. How many 23 month olds know when asked to grab some clecos go right to the box and hook me up lol
1735
Longassproject
Rofomoto
Postby Rofomoto » Tue Oct 30, 2018 6:45 pm
Any ideas on axles first drilling? Thanx billy
1735
Longassproject
Rofomoto
Postby Bryan Cotton » Tue Oct 30, 2018 10:11 pm
Billy,
My axle exploits are here:
viewtopic.php?f=39&t=578&start=370
One thing I remember, the Ti does not like really small drills. Definitely not #40, and #30 was iffy IIRC.
Postby WesRagle » Tue Oct 30, 2018 11:22 pm
Rofomoto wrote:Any ideas on axles first drilling? Thanx billy
Hi Billy,
If you are talking about the mechanics of drilling the titanium legs, this worked for me.
Ref. http://www.eaavideo.org/detail/video/29 ... Start=true
Do make sure the drill is slow and the bit is of the proper type.
Good Luck,
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Hummel 2400 w/Zenith Carb
Prince P Tip 54x50
First Flight 06/23/2020
42.8 Hrs. as of 10/30/21
WesRagle
Return to Photo Album
