Ken's Sonex 1243
Re: Ken's Sonex 1243
Postby Sonex1243 » Sat May 20, 2017 11:11 pm
Right panel coming along nicely. Piloted everything today except the motor mounts, flap drive mount, rudder tube mount and a clip in the back.
Ken S
SONEX #1243 N424SX (reserved)
Tail complete, wings done
Fuselage on gear
Jab 3300 received!
Sonex1243
Postby Sonex1243 » Wed May 24, 2017 11:46 pm
Right side completed down to the motor mounts. Trying to think of a bushing / drill guide for them since they came piloted to 1/8". On to the left side, down to the gussets, motor mounts and rudder pedal mount.
Then upsizing and the dreaded deburring and polishing!
Ken S
Fuselage on gear
Jab 3300 received!
Sonex1243
Postby Sonex1243 » Mon Jun 05, 2017 11:56 pm
Slowly moving along. Both forward fuse panels ready for up sizing and wing doubler fitting.
Ken S
Fuselage on gear
Jab 3300 received!
Sonex1243
Postby Sonex1243 » Wed Jul 12, 2017 12:11 am
I haven't posted in awhile because I, like others on a different post, have succumbed to "metal illness" along with vacations and flying. For now it was short lived as I only had it for a few days while polishing the forward fuselage sides.. It seems like a long time picking away at the construction of both sides at the same time, but, they are finally ready to be reassembled and riveted. I left the motor mount bolt holes one size under in hopes of finding a reamer to final upsize with in order to get the tight fit called for in the plans.
Everything upsized
Pilo "o" parts X 2
Finished up to 2 passes of "C".
Ken S
Fuselage on gear
Jab 3300 received!
Sonex1243
Postby Sonex1243 » Sat Jul 15, 2017 12:37 am
Finished the fuse sides tonight except for the rudder pedal mount. I wanted to leave that out until the phenolic bushings are made. I forgot I already made the flap bushings and cut another set from the remaining stock before I realized my mistake. New bar stock arrived yesterday from Wicks. Looks like time to dig the aft sides and channels back out for assembly.
Ken S
Fuselage on gear
Jab 3300 received!
Sonex1243
Postby Bryan Cotton » Sat Jul 15, 2017 5:24 am
Looks great Ken!
Postby Darick » Sun Jul 16, 2017 9:10 am
Polishing I see, yes? Looking good.
Darick Gundy
Sonex #1646
N417DG
First flight! 10/21/2017
Darick
Postby Sonex1243 » Wed Jul 19, 2017 10:36 pm
Thanks Bryan, yes Darick, I had a short bout with polishing disease! It won't be long and the aft fuse sides will be next..
I finished the aft tunnel web assembly. Is there really any reason not to rivet the assembly except the gussets even though the plans say not to? Looking ahead it doesn't seem to matter as the entire assembly is moved in and out during wing rigging.
All complete, clecod from the back side
Ken S
Fuselage on gear
Jab 3300 received!
Sonex1243
Postby Bryan Cotton » Wed Jul 19, 2017 10:42 pm
I remember asking that question. I think the one gotcha is near the end of the fuselage section of the plans. You have missing holes and they have one set of instructions for taildragger and another for nosedragger.
Postby Sonex1243 » Fri Jul 21, 2017 10:52 pm
The cross tie blues. I can't believe how crazy I have driven myself over these pieces. So much so that I had to mock them up with the cut off ends of the longerons just to make sure I was close.
bending and fitting everything
one set done
Anyhow, dug the aft sides out I started last fall / winter and clecod everything back together. The good thing is that I spent a lot of the winter edge finishing everything, just need to updrill, deburr and polish..
lower longerons ready for updrilling and vertical channel installs
Ken S
Fuselage on gear
Jab 3300 received!
Sonex1243
Return to Photo Album
