Sonex 1534 Photos
Re: Sonex 1534 Photos
Postby Gripdana » Wed Nov 19, 2014 6:27 pm
Last weekend I made a wing stand. I used Eric Witherspoon's plans and modified the base so I could use larger wheels. I have a lot of rough terrain so the wheels will come in handy. I figured out how to get the photo on her also.
<a target="_blank" href="https://imageshack.com/i/idf5t3wvj"><img src="http://imagizer.imageshack.us/v2/150x100q90/661/f5t3wv.jpg" border="0"></a>
<a target="_blank" href="https://imageshack.com/i/id3SgoFFj"><img src="http://imagizer.imageshack.us/v2/150x100q90/661/3SgoFF.jpg" border="0"></a>
<a target="_blank" href="https://imageshack.com/i/idgf1KbFj"><img src="http://imagizer.imageshack.us/v2/150x100q90/661/gf1KbF.jpg" border="0"></a>
Dana Baker
Scratch Built
First Flight March 8, 2015
Gripdana
Postby Gripdana » Wed Nov 19, 2014 6:29 pm
May be this will work better.
Dana Baker
Scratch Built
Gripdana
Re: It's a great day
Postby Courage1st » Wed Nov 19, 2014 9:41 pm
Gripdana wrote:I picked up my Aerovee today! I can't wait to start. I finally can see the light at the end of the tunnel.
Dana, that is someone with a flashlight bringing you more work.... :D looking forward to first flight video.
Bob
OneX "TBD"
Courage1st
Postby Gripdana » Thu Nov 20, 2014 1:14 am
Started the engine. I got the crank and parts cleaned. Added locktite to the allen screws. The crank is in the freezer for tomorrow.
Dana Baker
Scratch Built
Gripdana
Postby Bryan Cotton » Thu Nov 20, 2014 7:58 am
Awesome Dana! I hope to be there early next year.
Postby Gripdana » Mon Dec 15, 2014 12:01 am
The work on the engine has been slow due to 14 hour work days which only lets me get 45 minutes in on week days. Here is what I have done so far. There have been a few set backs but all have been resolved. This has taken me about 19 hours so far. I am going slow and making sure everything is right. I have had to split the case and double check the end play because I did not feel confident about how it went the first time. Here are a few photos.
Dana Baker
Scratch Built
Gripdana
Re: Sonex 1534 Photos-Aerovee build
Postby Gripdana » Sun Dec 21, 2014 12:16 am
Here is an update on the engine build. Everything has gone very smoothly. I had to get bolts that were slightly shorter than the ones that came with the oil pump because the ones supplied seemed to bottom out and I do not want to crack the case. Cutting the pushrods and installing the ends was very easy to do. I used a special c-clamp from work to press the ends in. Others have used furniture clamps. I was able to torque the gland nut using a pipe over my socket wrench and doing the math to use my body weight to get it to 227 ft lbs. I was able to get the engine off the mount and onto the table by myself. That thing is HEAVY. I am ready to mount the accessory plate.
I have tons of photos on flicker also at https://www.flickr.com/photos/90889513@N04/
Dana Baker
Scratch Built
Gripdana
Postby ScottM-Sonex1629 » Sun Dec 21, 2014 3:41 pm
Looks great Dana! Color and finish of yours is identical to mine...no wonder I like it!
Scott Meyer
Sonex 1629 - Sold...9/2019
ScottM-Sonex1629
Postby Gripdana » Mon Dec 22, 2014 1:00 am
Very productive day. I am almost ready to mount the engine.
Dana Baker
Scratch Built
Gripdana
Postby daleandee » Mon Dec 22, 2014 1:56 am
Hi Dana,
Your engine is a great looking example of an Aerovee! I did notice that it appears a few of the case nuts don't go on far enough to engage the nylon lock portion of the nut. Is that the way they are sent now? Is that acceptable? Perhaps they are and the photo is a bit deceiving.
Not meant to be critical, just curious ...
Dale
N319WF
Return to Photo Album
