New propeller a "major Change"?
Anything related to props
Postby kmwoody » Fri Jan 09, 2015 3:59 pm
Hi all,
I am wondering about my compliance since I changed my prop from a Sensenich to a Prince. Would this be a "major change" on a Sonex since it is the same length and pitch, and at the time of registration, recommended on the Sonex website, but not at the time I changed it. Could someone please clarify this for me.
Ken W
Sonex 959
Aerovee 282 hrs.
kmwoody
Re: New propeller a "major Change"?
Postby Fastcapy » Fri Jan 09, 2015 5:10 pm
Mike Beck
Oshkosh, WI (KOSH)
Sonex #1145 N920MB
Fastcapy
Postby kmwoody » Fri Jan 09, 2015 6:23 pm
Thanks, that's the explanation I was looking for. I appreciate the indepth answer.
Ken W
Sonex 959
Aerovee 282 hr
kmwoody
Postby mike.smith » Fri Jan 09, 2015 6:33 pm
kmwoody wrote:Thanks, that's the explanation I was looking for. I appreciate the indepth answer.
Ken W
Sonex 959
Aerovee 282 hr
I have likewise always read and been told the same thing. If you replace with the same propeller, no problem. Anything else then you go back into Phase 1 for a short time. If you were inspected by a DAR and not an FAA inspector, you notify the FSDO and not your DAR. Often it just takes a letter of notification, and from some reports some FSDOs will barely even respond back, while others are more precise about the requirements.
Postby Fastcapy » Fri Jan 09, 2015 9:51 pm
Mike Beck
Oshkosh, WI (KOSH)
Sonex #1145 N920MB
Fastcapy
Postby Fastcapy » Fri Jan 09, 2015 9:52 pm
Mike Beck
Oshkosh, WI (KOSH)
Sonex #1145 N920MB
Fastcapy
Postby radfordc » Sat Jan 10, 2015 12:34 am
Legality aside, how would anyone know if you had changed props or not? According to the EAA webinar on registering an experimental plane a prop logbook isn't required for a plain fixed pitch wood prop. Is there a requirement to have the prop identified in any other document?
Postby mike.smith » Sat Jan 10, 2015 12:49 am
radfordc wrote:Legality aside, how would anyone know if you had changed props or not? According to the EAA webinar on registering an experimental plane a prop logbook isn't required for a plain fixed pitch wood prop. Is there a requirement to have the prop identified in any other document?
Like most of these kinds of things nobody finds out until you have an incident. Then you risk the possibility of scrutiny. The whole reason for the new Phase 1 is just to make sure it works as intended, and proves safe. Not bad advice whether it's required or not. :-)
Postby daleandee » Sat Jan 10, 2015 2:31 am
My DAR took the prop information from me (in our over the phone conversation before he came out) but I have no idea what form that information was processed on. He wanted info on the manufacturer, type, pitch, and the serial number. I'm one of those guys that keep separate logs for the engine, airframe, and prop. I agree with Mike that playing by the rules on this is a great idea especially if there were ever an accident and the FAA and insurance companies start looking for a reason to make your life miserable.
Dale
N319WF
81.7 Hours
Postby Fastcapy » Sat Jan 10, 2015 2:34 pm
Mike Beck
Oshkosh, WI (KOSH)
Sonex #1145 N920MB
Fastcapy
Return to Propellers
