eBikes
For non Aviation related discussions.
eBikes
Postby WesRagle » Thu Nov 18, 2021 6:37 pm
Hi Guys,
Just finished the eBike conversion. Only took about a day. Would have been much quicker if I had known anything about bikes.
The things are a blast. I yawned when my buddy got his .... until I rode it. The things are just fun. If you have never ridden one I would suggest you give one a try.
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Hummel 2400 w/Zenith Carb
Prince P Tip 54x50
First Flight 06/23/2020
42.8 Hrs. as of 10/30/21
WesRagle
Re: eBikes
Postby BRS » Thu Nov 18, 2021 7:27 pm
Hi Wes,
Looks like you used a BBS02 motor (or is that the HD). Yesterday I just finalized a build of an electric trike for the brother of a friend who has mobility struggles. We eliminated the display and throttle and installed a simple toggle switch. Worked out well.
Post another picture when you figure out how to put that bad boy in the onex baggage space..
-Brock
Sonex-A (s/n 1013)
R2300, P-tip 54/50
Center Stick
V16, TT22
BRS
Re: eBikes
Postby GordonTurner » Thu Nov 18, 2021 10:52 pm
…exactly what I was thinking Brock. Lets see it in the plane.
My wife and i have bromptons, which fold pretty small. No chance of even getting one into baggage on the waiex. I’m seriously thinking about a baggage pod. They’re about 10” thick when folded, and about 24” square.
Gordon
Re: eBikes
Postby WesRagle » Fri Nov 19, 2021 10:52 am
Hi Guys,
It's a BBSHD 1000 Watt. I wend from a 46 to a 42 on the front sprocket. It climbs like crazy. First uphill test I didn't lean forward and it nearly came out from under me. I'm still spinning up on eBikes but from what I understand the 1000 Watt bumps it up to a class 3 bike. A 250 Watt motor is class I (in Texas) and the law treats them just like any other bike. The kit came with four 250 Watt stickers :-)
BRS wrote:Post another picture when you figure out how to put that bad boy in the onex baggage space..
GordonTurner wrote:…exactly what I was thinking Brock. Lets see it in the plane.
OK, I'm on it ;-)
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Prince P Tip 54x50
WesRagle
Re: eBikes (It Fits!)
Postby BRS » Fri Nov 19, 2021 7:52 pm
Here is how I put an E-Bike in the Sonex (leave one wheel home)....
Lay it down, Strap it in.
Easier to roll around than a carry-on suit case.
30 mile range
-Brock
Sonex-A (s/n 1013)
R2300, P-tip 54/50
Center Stick
V16, TT22
BRS
Re: eBikes
Postby WesRagle » Sun Dec 19, 2021 1:29 pm
Just back from a camping trip. About 20 miles a day on the new bike. The most smiles per $ I've had in a long time.
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Prince P Tip 54x50
WesRagle
Return to Off Topic
