Drill bits to drill main spar attach holes.
Posted: Tue Feb 04, 2014 12:02 pm
I've read and studied a lot of different methods to drill out the final size of the attach holes, including some creative modification of drill bits to help prevent ovaling of the hole (such as grinding down the tip of a larger bit to pilot the bit through the hole). I believe I just discovered a drill bit that can be purchased and do exactly what most of these drill bit modifications attempt to do.
http://www.panamericantool.com/double-m ... s-937.html
Item #13-250 is a 3/8" double-margin bit with a 1/4" pilot. I haven't purchased one yet and my only question would be how sharp is the pilot portion, as the idea is for it not to do any cutting and only follow the existing hole. The double-margin feature basically helps make the hole have a near-reamer finish.
Right now this is the front-runner for how I believe I'll drill the attach holes, I'm curious what others think of it.
